How to DIY a tool, putting case halves together WITHOUT A PRESS
jmssaws
Banneded
9:15 AM
I've watched my neighbor split cases and assemble them with the oem tool and it sounds awful,popping and squeaking.
I heat it up and put it together with no effort what so ever, no pressure or forcing. I always use heat so seals are last.
10:15 AM
I've put the pto bearing in and had it fall all the way through when they were plenty warm. If I have to pull the cases together any with bolts the crank doesn't turn very free. If they drop together by hand it's usually free spinning.
beaglebriar
The Peanut Gallery
10:15 AM
Warren Center, PA
The 372 I just did got stuck when it was part way together. I pulled it the rest of the way with a similar tool to Matt's. It spun absolutely free when I was done. Kinda surprised me.
I'll always use heat but these tools have their place. I made mine to push the seals in. I think that's where they'll really shine.
10:15 AM
Yep. I may make a set for the clutch side of a 372 and the 44/46/66
Mattyo
Youtube speciawist
10:15 AM
Farmington, CT
Certainly you can use a lathe...but it's absolutely not needed. 3/4" threaded rod...some washers ...old bearings 6202and 6203 inner races. Some nuts and a small piece of 3/4 copper pipe if you want to get fancy like version 2.0. If it takes you more than 20 minutes to build a tool you I'd be surprised. No harm in making nice tooling...but doing it by hand seems to work fine. The hardest thing is finding the taps for pto side. But they are on ebay and pretty cheap.
Tor R
Novice, Leg model #2
4:15 PM
Mandal
Mike, you only need to make 6 bolts and you have covered pretty much the whole line up to Husky from around 1985 and until today.
Here is an overview of thread system Husky has used:
Your bolts should be threaded 60mm, its always best to have a bit longer bolts then needed.
You need to lathe out two sockets, one for 15mm crank axel and one for 17mm.
Here is an OEM kit who fit 346:
There is a bit more reading here:
http://opeforum.com/threads/crank-mounting-tool-crank-threads.4804/
Mattyo
Youtube speciawist
10:15 AM
Farmington, CT
Essential info there Tor... thanks.
I know husky 340, 345, 350 and 455 rancher all use the same pto and flywheel side threads as 346xp ... so you can add those to that list
Those shop tools are very nicely made, but I like my version 2.0... I can use my impact on it if I want :)
Mattyo
Youtube speciawist
10:15 AM
Farmington, CT
oh, since those pto sides are all left hand thread, likely I need to expand my collection of taps a bit...
Tor R
4:15 PM
Mandal
never thought we needed tools for 340/345/350 since they are clamshell design.
50/51/55 goes together with 254/357/550 thread system.
I like factory tools, but to be honest, I more prefer the socket system I draw up instead of Huskies different sockets system who has a multiple solution for both bearing and seals.
the only one I didnt add in the system is threads for 133/234/238/42/242/246 since those saws are super rare.
Around 84/85 Husky more or less left the UNC/UNF and went for metric system.
Mattyo
Youtube speciawist
10:15 AM
Farmington, CT
With regards to 350s ....yup..I'm a dingleberry....not need for tools though it is the same thread sizes.
Ya...I'm liking the diy tools. :)
Mattyo
Youtube speciawist
10:15 AM
Farmington, CT
Really good video Matt have used heat and freezer for years will have to try your method on my next project thanks for sharing very informative my friend thanks for sharing:headbang:
Thanks!
I'm gonna keep working on it too. Seems to me like the husky shop tools are very nice, but it also seems to me like they never chose to improve much on the design once it was made. I'm gonna keep trying to improve on what I've got. tis interesting :)
10:15 AM
With some bad clutches with busted spiders and a little welding I can probably make all of mine and not need the left hand taps.
