- 1:07 PM
- Jan 8, 2016
- Farmington, CT
For indexing depths I do get it. it certainly would be tricky if you truly have a depth you need to go to. OTOH, why would you want the bearing protruding into the crankcase at all? That doesn't seem to make sense from a design perspective. I know that the 660 bearing doesn't have a seat/stop on the outer part of the crankcase, and again... this doesn't make much engineering sense to me.
I'm gonna do another 660, but for the purposes of the china 660 builds, the bearings are already installed in the cases. So all I need to do is pull the crank through without heat next time.
Just did my sawmill bandwheels. Double stacked bearings. They press in, positive seat. Snap ring retention (as a double check). Basically no way to screw that up lol.
I'm cleaning off my bench now to see if I can do this 372 video right.
