How tight do you keep your chain?
TJ the Chainsaw Mechanic
Old Homelites rule!
4:40 PM
When the chain touches the bar....and probably a 1/2 turn from there...Never really paid attention. I just pull chain up on the top center of the bar...and if it pops back into place easily...I know it's fine...same with the bottom. Stihl actually does recommend that after using the saw you should loosen the bar nuts and relieve tension on the chain to help keep it from stretching. Never have done it myself.
wildroamer
Winning!
7:40 PM
Vermont
Tighter than Linda Lovelaces cootee!!!!
So, this about do it then?
CR888
9:40 AM
Australia
Till its tight enough to create smoke signals. Who really needs an Arctic model, plenty of other genius ways to warm the saw components up.
wildroamer
Winning!
7:40 PM
Vermont
Honestly, I actually had a tendency to run it a bit looser than I do now. I've taken to giving it that little extra 1/4 turn after the chain slaps the bottom rail.
P.M.P.
Stiff Member
7:40 PM
Michigan
I have 3 346 and they all have to be around 1/8 of an inch from the bar before the nuts are turned or they are to tight.
skippy
Husqvarnas Sawyer
7:40 PM
Pennsylvania
It depends on what I am doing .
That determine s the tightness
Husqy lover
6:40 PM
Minnesota
My mom doesn't let me put a chain on yet, or start it, I have to make engine noises with my mouth
Ironworker
7:40 PM
Orange County NY
I tighten up till you can pull a 1/4" space between bottom of cutter and top of rail, then I give the tensioner a quarter turn.
