Iron.and.bark
- 12:21 AM
- Feb 26, 2016
- Australia
You must have dirty wood or real steep angles ,i was using ripping chain off the usg grinder ,but tried square one day ,full skip ,same chain i fall with or cut firewood ,at 15 degree top plate i am getting a decent finish with square ,i looked at my round and the cutting edge is thinner than my square and more fragile ,may be why the round is dulling faster ,cutting edge not as thick or strong ,granted i am cutting softwoods ,doug fir and western red cedar ,and it was freshly fell so wet inside still ,not a bit of dirt on the logs ,was moved with a skid loader with forks right away .
This is not the same chain ,but same grind angles i was using View attachment 27014
It's abit chalk and cheese really. See the hardest wood thread. What maybe a sharp enough chain for a soft wood is dead blunt in a hardwood.
Milling full comp, chisel with raker angles at 10 on ~40" bar on alaskan with 404 gets me around time specified.
Using a 24" bar on logosol, with full comp chisel .325 at 0° angle running a 10 tooth sprocket may get me 45 mins in the softer hardwoods I mill.
