Coupe
- 3:40 AM
- Mar 4, 2024
- New Zealand
If it does have an idle jet that is a bit small be careful drilling it a bit larger do it
in very small ammounts if you go to far an go the other way it will start flooding
and then you have a bigger problem. Most of the new motors these days are set to run qute lean.
And as said in one of the other posts a lot of them surge at idle. I have a kohler on a logsplitter that
has a wee bit of surge at idle but as soon as I power it up it runs fine so I am quite happy were it is.
