Homemade Reduced Weight Bar
Jon1212
Birch! Please.....
11:53 AM
Utah, unfortunately.....
I mentioned 'micro-balloons' in an earlier post. Adding these to the epoxy resin thickens it, and converts it into a paste or filler. Used a lot in boat building.
West System is one of the better known brands, and offers a lot of technical info. You could contact them, describe your application, and ask their advice.
http://westsystemcom1.site.mobi/app/the-105-system/4965226/36/
Philbert
Thanks for all of your pertinent advice, @Philbet(gluten free cracker excluded).
Jon1212
Birch! Please.....
11:53 AM
@junkman
Bar Flex comparison update(hanging 10lb weight from midpoint. All bars are 32" 3/8 050 D009.
32" Power Match with cutouts- 7.76mm
32" GB Roll Top no cutouts- 3.43mm
32" Power Match RW- 9.23mm
32" Power Match with cutouts filled with two part, and cured for 15 hours- 6.30mm
Jon1212
Birch! Please.....
11:53 AM
So leaving the little bits in the middle helped rigidity a lot .
Apparently.
I'll be curious to see if the flex tightens up on this one, after the epoxy has 24-48 hours of cure time.
I'm going to swing by FedEx, and weigh the modified bar to see what the accurate "actual" weight is.
Isaac
1:53 PM
Concord, NC
I like the results. Curious to see the weight comparison between the factory RW bar and the homemade one.
Jon1212
Birch! Please.....
11:53 AM
So I took my used Oregon 320RWDD009, and my Homeade version by FedEx today.
Oregon RW= 3.25lbs
Jon1212 RW= 3.75 lbs.
I've got enough room towards the tail for another cutout, so I'll go ahead, and get that done, which ought to put it closer to 3.50 lbs.
Jon1212
Birch! Please.....
11:53 AM
Holy chit we didn't think you'd take the peanut butter comment to heart!
J/k great stuff so far.
Hahaha! +GFY.
I need to figure out a way to smooth out the filled areas. The discoloration is from trying to high speed sand it. I'm thinking a random orbit might be better.
