T.Roller
- 8:34 PM
- May 11, 2016
- Southeast, TN
JerkNo paint present, nor will there be any when I am done.
Or ask someone else to weigh one?.......
Well of course he does!Maybe Chris_PA has an app for that, as well?
Truthfully, the hardest part is done. Cutting between the holes is easy and fast with a good cutoff wheel. Then a little finishing, removing burrs and smoothing things out. Dealing with the epoxy will be fun.So after busting a few teeth off of the first bit, I got my RPM's, oil use, and downward pressure sorted out. Thankfully, @USMC615 had sent me a few spare cutter heads, so the next five holes were much easier.
Now it's time to remove the steel between the bore holes.
Brian,Is it possible to see a flex comparison with the metal removed vs the stock bar .
Brian,
Any thoughts on how to perform this test?
I am thinking hanging a 10 pound weight perpendicular to the flat surface with the other 32" resting across the top of the flexing bar. This would allow me to take a measurement of the amount of flex. Then I would just swap the places of the bars for comparison.
The GB is slightly narrower rail side to rail side, but that should effect a flexion test.
I did read today on Madsens that a conventional 32" Power Match bar weighs 4.7 lbs, and a Reduced Weight bar of the same dimensions weighs 3.3 lbs.
That would be swell. When you habe thyme, Cousin.Due you want me to weigh mine to see if they are correct?
Next time.I would just bolt a power head to one ,and maybe c clamp to a work bench ,then measure the flex to the floor ?View attachment 33552
Since this is a test bar, maybe you can fill each void with something else, to see how easy each is to work with, as well as to see how each holds up? Kind of like a pavement marking test?
Fill one void with epoxy; one with HDPE; and one with some tasteless, gluten free, non-GMO cracker?
Philbert
Peanut butter works well
I mentioned 'micro-balloons' in an earlier post. Adding these to the epoxy resin thickens it, and converts it into a paste or filler. Used a lot in boat building.I need something that has more of a paste consistency at application.
