HOMELITE Homelite Thread
Hoggwood
12:39 AM
Above the 49th
I've been playing around with other coils to replace the infamous Prestolite "Blues" found on the XL-76's and such. I have some that are running well on the original Prestolites, others I have baked to bring back to life (somewhat) and others just plain dead. A lot of trial and error and I think I have found a winner. The carb on the saw is an SDC-81 with the accelerator pump. It needed a complete overhaul including pump and new check valve. Coil is off of a little Frontier - Repco with external trigger(?). Rigged up a bracket to mount the coil. First test in wood. Might have to play with the timing a bit more. No key and flywheel advanced a fair bit with respect to the original coil. Ideally, I would have liked to use a light and time it properly. No light, just trial and error.
These are very strong saws and can cut fast in the softwood around here.
A test cut in the front yard...http://vid26.photobucket.com/albums/c104/Hoggwood/Homelite XL-76 Ignition Swap_zps9w14dqhx.mp4
Homelite XL-76 Ignition Swap - Repco 2.jpg Homelite XL-76 Ignition Swap - Repco 1.jpg
Kozak Logging
2:39 AM
Wisconsin
I would like to know what the following homelites are... The older 3 anyways. I believe they are 1950's era, one says model 600D and the other is a model 17 and the other says WIZ. I would like to know cc's and hp specs if anybody knows for each. I'm going to get them running again as I got them from my Uncle Kenny as they were his dads who is my grandpa. They went from my grandpa to his wifes brother. So there family saws :) Thanks. I found some info, but the WIZ doesn't say model 55, 66 or 80 so is there anyway to find out? Thats the one with the orange serial number.
