High end oil debate belray h1r vs motul 800 2t
Witch oil do you think is best
  • Belray h1r
  • Motul 800 2t off road
  • I don't even care
  • Honda hp2
Results are only viewable after voting.
jakethesnake
I Am The Snake
4:22 AM
Here & Now
Just a way off question but can you do anything to clean a piston up without breaking the saw open? Like use sea foam or even any soaking on top pistons or will that screw up the bottom end?
smokey7
4:22 AM
Detroit
Wow those klotz pistons look terrible. I have never ever had a engine look like that that was my own. I have torn down engines with probably 500+hours. Most everyone I deal with uses echo/shinny, pure gaurd, lucas, citgo, mystic, penzoil or amsoil. I would be furious if I had a motor look like that with 2 gal of mix. I have seen several other motors ran on klotz that looked great. I question if it's the strato saws combined with autotune causing all of the sludge and coking? That piston picture is going to haunt my dreams.
Moparmyway
Its just a saw
4:22 AM
In a meeting
Harvey, sometimes, when looking for max output from a specific combination, the piston is flipped backwards to allow a porter to grind in fingers. Also, the builder may opt to remove one of the two rings and even relocate the ring pins .......... all to keep the ring ends out and away from any port, added or already there
CR500
4:22 AM
Western NY
Don't worry.... I ordered some kl 200 last night....
I do think some oils are excessive at 32:1 even for ported saws.
Which brings me to a new question.
Is 50:1 safe to run with oils that have high rpm limits along with flash and viscosity numbers like Klotz Super and Motul800?
Sent from my non internal combustion device.
Sty57
3:22 AM
Land of Cheese & Beer
I don't run as much as a lot of you guys.
This is what Dad and I have been running. We're on the fourth gal. so far so good.
I friend of mine gets for me at $20 a gal. I can pass that up.
Cut4fun
Redneck Chainsaw Repair
4:22 AM
Ohio
Whats it going for now? Last I seen was around $130 a 10qt case delivered.
I swear by kl-200 and even run it with ethanol fuel. Tested it for over a year in a old set aside batch and it never separated. Even when left open on purpose a qt at a time. :)
Still running kl-200 32/1 in everything stock, weedeaters and never seen the crap the super was doing. kl-200 all the way. :campeon:
Moparmyway
Its just a saw
4:22 AM
In a meeting
Throw us a picture or a few of some of your long use pistons with KL-200 when you can please !
Cut4fun
4:22 AM
Ohio
Dont plan on pulling any out anytime soon. AFM 066 piston in the 505 and a AFM BB372 in the 475. All have been run hard on this set up.
If I get down south and get those big poplars on the ground and logged. I might pull them down then for a look see. Because I am thinking about putting a 445 on my wild thing 505
Keith Gandy
Maxima K2 40:1 87 Pump Gas
3:22 AM
Provencal, Louisiana
Screenshot_2016-03-03-11-48-24.png 10 tanks , 550xp, 87 efree with Klotz Super @ 40to1. Plenty of oil in the bottomend at 40to1 and top of piston was a thin dry hard layer of carbon. So far so good. I was takin her down for porting and figured I would shoot yall a few pictures Screenshot_2016-03-03-11-48-24.png20160303_074937.jpg
Cut4fun
4:22 AM
Ohio
View attachment 13848 10 tanks , 550xp, 87 efree with Klotz Super @ 40to1. Plenty of oil in the bottomend at 40to1 and top of piston was a thin dry hard layer of carbon. So far so good. I was takin her down for porting and figured I would shoot yall a few pictures View attachment 13848View attachment 13849
Thats what I like to see too. Just scared of the stuff aka super after what I had happening. Then seen more folks posting even worse then mine.
Yet to see Original do that stuff yet.
Thanks for your info.
Definitive Dave
Piss Rev Mafia Member
4:22 AM
Central Ohio
do I look like I do any work, let alone in cold weather :)
them motorcycle guys are real particular about their oils :) well over 100 types there today, more than 50 kinds of air filter oils, it was crazy!!!
Cut4fun
4:22 AM
Ohio
If you leave your mix outside in cold shop etc it will even fall out of suspension. Wont stay mixed in cold weather.
Read alot on it years ago and it seemed to be a good warm weather oil. Only a few complaints of it gumming up the rings.
