spencerpaving
- 7:02 AM
- Jan 6, 2016
- central new york
That is absolutely sick! Love it!...made a new large volume pipe for my 084 and installed a wb carb..tested this am in some 13"
Pre-ignition....low side is a little lean...Yea running funny fuelAlways wondered why the run-on after a few cuts?
Is that the phunnee fuel causing that?
Can it be reduced by fattening the low circuit or is it kept lean for a reason?Pre-ignition....low side is a little lean...Yea running funny fuel
I richened it up after I made the vid...it was fine....but I ran it before the vid so the saw was hot and that aggregavated itCan it be reduced by fattening the low circuit or is it kept lean for a reason?
I know those carbs need to be opened up quite a bit to run that juice
YepI richened it up after I made the vid...it was fine....but I ran it before the vid so the saw was hot and that aggregavated it
Thanks...I don't think this will pull a 14...I only know of a couple 140's or bigger running 14....mine is still stock bore and stroke....but I might be doing a 140 huski this winter....Beautiful work, if you want to try a 14 pin I gotcha covered
Did you cut down one of the cannon belly bars?
I really want a fatty 60dl for my 084
