- 6:00 AM
- Dec 26, 2015
- The land of pleasant living
I'm an old fashioned type of guy but I've got this 550 thats got AT. Saw fires on a prime but the problem is between the tank and the cylinder, ala carb. The gaskets look new, needle looks good. Screen was a little funky but not bad. Primer bulb did not pick up gas, but there was gas in the carb. When I was taking apart carb tried the primer bulb and could hear air moving, so dont know what thats about. Sprayed carb cleaner in every hole I could find, but didnt want to f### with the welch plugs. Used to spraying out the low and high passages, but I think they are on the side with 5 or 6 little holes. Anyway, when spraying carb cleaner in one of the holes I heard a pop and some cleaner came out of the jet into the bore. So I'm thinking that was plugged. Anyway, anything else I could do to it? How about the solenoid? Could that be moving no fuel? Thanks.
