Husky 128LDX fuel lines
Fleethirte
7:34 AM
Virginia
What fuel lines does the trimmer / pole saw 128LDX use?
Are they two pc?
I know one goes to carb and one goes to primer bulb but can I use universal fuel line?
Poleman
5:34 AM
Rapid City,S.D.
You can use any line that will have a good seal and fit. I like using the black small echo line for the fuel line then a Poly ( yellow-blue) line for return just so one can see the purge is pulling fuel.
Fleethirte
7:34 AM
Virginia
thank you!
it had little nipple connectors in the holes of the gas tank? are those needed?
Fleethirte
7:34 AM
Virginia
thank you!
i replaced them yesturday. i pressure tested and it leaks a small bit around the cap. is this normal since it dosent have a vent!
Fleethirte
7:34 AM
Virginia
how easily does the drive shaft slide out?
i hooked up the attachment now that i got it running good. but it don’t spin…. took it back apart and it looks like something is missing in the drive shaft.
