Help with an air leak
decableguy2000
10:14 PM
WNC
Having a hard time nailing an air leak on a Husqvarna 371. Clutch side seal replaced twice, mirco O-ring replaced. I can't see where my bubbles are originating from. Oil pump screws sealed. looks like it is coming from under the worm gear. Any one have a way to un-crowd the area to see better. The manual states pump up to 80kpa and wait 30 seconds and should not be under 60kpa, mine will hold longer than 30 second.
jockeydeuce
7:14 PM
BC, Canada
I put the clutch on to hold against the seal sleeve, but leave the worm gear out so you can see better where it's coming from....You might have a nick in the bore for the seal in the case....You have to be very careful popping out seals
