- 1:42 AM
- Dec 30, 2015
- Georgia
Fuel line
This, seen it more times than I can count, right where the line comes through the tank.
Joe
Fuel line
Almost every one I get in the shop has a hole in the fuel line.
the worm gear sets on it?Washer goes on top.
Yes sir. The washer is a thrust washer of sorts. Washer sits on shoulder of sleeve, worm gear sits on washer.o-ring can be slid on before seal down against bearing and install seal and push sleeve down through seal to sit on top of o-ring?
thanksYes sir. The washer is a thrust washer of sorts. Washer sits on shoulder of sleeve, worm gear sits on washer.
