- 6:01 PM
- Dec 26, 2015
- The land of pleasant living
Not sure if theres an umbrella beneath that or not... btw, u send the chit?
No I *f-worded up again, like usual. I did get it all in one spot but nothing got packed Sunday night. Your at the front of the line and yours is the free chitNot sure if theres an umbrella beneath that or not... btw, u send the chit?
Question is does my small base have one in there factory. It looks like a grub screw in the tower part imo. If so the umbrella might not be there from the factory idk for sure but trying not to break my tank. Saw is very nice. I have a ragged 360 that needs a case brake pin repair or another case. No need for a big saw. Light weight was my plan with a wide fast cut.Accelerator pump check valve for a Holley carburetor will work also in place of the orange umbrella.
Sure doesAccelerator pump check valve for a Holley carburetor will work also in place of the orange umbrella.
Those kits suck imo.I guess they just push on and a very tight fit, maybe even a lip it pushes over.
The reason I say this is, I have a 026 that never had one when I got it. I looked at the ipl and with the serial # I needed a white thing on the top, also one of them red flaps in the tank one way valve things.
I fitted them and it leaks less than before. But the white thing is still easy to pop off.
but on a side note there was a bulletin for a 200t, some tank vent white thing it leaked. They had a mod kit (not cheap) that replaced the old design. I tried to fit it to the silly 044 tank vent (plastic tube with two grub screws in.) Well it never worked as there was no place for the white cup thing with the lid on to sit/hide..
