Corkey6650
Active OPE Member
- 1:34 PM
- Jan 10, 2021
- michigan
Hello everyone, This is my first ever post on any forum and also my first time tearing into a chainsaw so please forgive me with any mistakes. My Stihl 036 pro ran away on me couple of years ago so I bought a MS 311.I do not like the new designed av system as it feels too loose to me so I decided to try and repair the 036. When it ran away it got so hot that it would not shut down with the switch so I had to quickly dump out the gas mix. I think the flywheel side seal was the root cause of the problem as I hope you can see in the pics I uploaded. I will be replacing the wrist pin bearing , crank case bearings , the seals and gaskets. My biggest concern is the piston , cyl , and case. The case is heavily pitted on the flywheel side but not as much on the pto side. The piston looks ok to me but the rings have black spots on them that catch my fingernail as I run the along the top edge of the rings. Any other info you need to try and help me, just let me know . Sorry about being long winded . Thank you in advance
