Height adjustable depth gauge tool
Junk Meister
9:39 PM
Nebraska
Note that this one is a single, ‘U’-shaped piece, which is different from the one in Post# 2 and #6.
More info in that thread, including instructions.
Philbert
I have 1 of these. They cut to the chase for checking clearance. I like how it fits and feels. No second guessing.
The "More INFO" Part at the bottom of the pics,,, I would like to read that. The only draw back I have is verifying .025" or .030 , I usually just grab a different gauge to double check.
EDIT
"It showed up as I was posting this" thanks
4:39 AM
Philbert
Chainsaw Enthusiast
9:39 PM
East Dakota
Wow! Somehow I missed this post!
Was focused on the older, Oregon models!
Up on ebay, and Conrad has it in stock too.
Thanks for following up on this.
Lots of good information in that link, but not available in the US.
(I like how eBay translates the brand name ’Pferd’ to ‘Horse’!)
Philbert
hdyk
11:39 AM
Japan
start from about 0.2mm to over for 3/4 pitch
Sloughfoot
7:39 PM
Norcal
Is it plastic?
Philbert
Chainsaw Enthusiast
9:39 PM
East Dakota
‘Rather than relying on numerical scales, this gauge features a dial screw that allows you to make stepless adjustments to the filing angle—tailoring it to your specific feel and preference—while simultaneously visualizing and verifying the setting. The starting point is set at approximately 0.2 mm ("Hard & Hard"), with a 3/4 setting at 1.7 mm; settings beyond this range are also possible.
It is compatible with all pitches, gauges, and sequences. For those who prefer to manage settings numerically, simply measure a single cutter using a caliper to determine the precise numerical value, and then align the dial accordingly.
The third image provides a comparison between a brand-new C85 cutter and the gauge's starting point.’
(Google Translate from website description)
Philbert
hdyk
11:39 AM
Japan
Philbert
correct compleatly. this item helps not for everyone, for expert or racers they wanna win with sure & easy custom way.
hdyk
11:39 AM
Japan
That's too bad. I was hoping for a metal one. A plastic one won't work the same, especially a 3D printed one, which this appears to be. I wish you the best
That's too bad. I was hoping for a metal one. A plastic one won't work the same, especially a 3D printed one, which this appears to be. I wish you the best of success, nevertheless!
Even plastic one works as a checker. This is the first test step for achieving metal one having numerical number but it needs quite higher price for low volume with precision. I just now opened the door closed for about 70yrs by OREGON.
Sloughfoot
7:39 PM
Norcal
Philbert
Chainsaw Enthusiast
9:39 PM
East Dakota
Pferd says "The depth gauge should avoid contact with the file wherever possible, as this can alter the dimensional accuracy".
I don’t file on any of my depth gauge tools.
If the tool is soft, the file could damage it.
If the tool is hard, it could wear the file faster .
Place. Check. File.
Philbert
