Has anyone messed with a 375k?
MG porting
1:23 PM
Wa
What all is different on ignition? I read a conversion thread on another sight where a guy just threw in an aftermarket coil on it.
I would highly recommend leaving it stalk they don't see the lode of like a chain saw and there wide open throttle thus reason for limited coil.
Absolution
4:23 PM
WV/NC
I was thinking one day I could covert it over to a saw and buy a clone 372xp and throw the cut off attachment on it.
Absolution
4:23 PM
WV/NC
Sure looks like it. Original coil likely failed and someone stuck a 372 coil in there.
Little on the dangerous side to run a concrete blade at 13,000 rpm, so be careful on dropping different coils in there.
Good thing I have a tach.
Absolution
4:23 PM
WV/NC
What is air gap on 372?
Absolution
4:23 PM
WV/NC
So believe it or not that piston and cylinder has compression. Lol. Not gonna run it but I find it amusing. However I think the magnets on flywheel or coil is bad spark is really anemic.
Absolution
4:23 PM
WV/NC
So last night I ordered a fly wheel and unlimited coil and bearings W/ seals. They were combination of aftermarket parts for $26. At least this way I can see if coil or the magnets were bad. The bearing I'm a little hesitant on since I've only had experience with the 070 and 660 AM bearings. I may still order a set of OEM or equivalent. Dealer quoted $16 a piece for new bearings. If anyone knows a better place for pricing that would be great. I'm also tempted to but the cheapest piston I can find and run this cylinder into the ground. Who else wants too see how long it lasts?
Edit: should I do a one or two ring piston?
ny15
4:23 PM
Lima NY
Where are you going to get the cheap piston from?
Absolution
4:23 PM
WV/NC
Ebay probably. The cylinder looks like an aftermarket. I'm going to remeasure the bore tonight.
Absolution
4:23 PM
WV/NC
Cylinder is 52mm and is piston 51.35 depending on area.
qurotro
Cookie Cutter
3:23 PM
Ar
From I've seen, Mahle make all the cylinders for 372 family (non XT).
If you dont see Mahle on the jug. It's aftermarket.
qurotro
Cookie Cutter
3:23 PM
Ar
Crank bearings are regular 6202 C3 tolerance. OEM is just SKF. You can use other brand.
