Gun and knife oil thread
USMC615
Fapper Fi
5:31 AM
Mid-Georgia
Yep most "gun" oils are a gimmick, they charge 2or 3 bucks for an ounce of oil. Remoil for example is mineral oil with silicone. Motor oil is fine. That's the main ingredient in the NRA oil. I made a gallon of it for about $25. That's less than 20 cent per ounce. It will last the rest of my life.
Sent from my moto g(7) power using Tapatalk
Crazy what folks want now for MC2500...take a look at the prices per ounce.
ammoaddict
5:31 AM
Granite Falls, NC
I just looked it up, I had never heard of it. I won't be buying any of that. Firearms don't need as much oil as some people think. A drop in all the right places is all you need. I've seen people spray lube all in the action then it runs everywhere and attracts burned powder and makes a grungy mess. I keep white lithium grease in a plastic syringe that I grease slides and such with. I keep the NRA oil in an eye dropper bottle that I oil the action parts with.
ktmtigger
5:31 AM
Got a bottle of this from the parts supplier for free worked well so far
mdavlee
Hillbilly grinder
5:31 AM
TN
I’ve used Frog lube, Mpro7, Rem oil, and several others. All of them work decent when applied correctly and not dripping off there. Thebb B only ones I’ll soak in grease is the AR15. They run better with some grease over a lot of oils.
N8TE
4:31 AM
South Dakota
I use Lock-eez to coat the bore of a clean barrel and also on bolt and carriers. Any oil will do to wipe down the exterior. The lugs of my bolt guns get a thin layer of shooters choice grease.
RI Chevy
5:31 AM
earth
Lucas makes good stuff. I'm going to try their 2stroke oil when I finish my quart of amsoil. I used to use Remoil until I mixed up the NRA stuff. Now it's all I use.
Lucas 2 stroke oil sucks. Fare warning, don't use it. It's been tested by a few. Its dry
Flint Mitch
5:31 AM
Michigan
I've read numerous articles on firearms lube and there is a lot of sentiment out there that using a good quality synthetic engine oil is a great option, too. I'm on several waterfowling forums and some fellas use Mobil 1 on their Benellis , Berettas, Brownings, Remingtons, etc, etc, and get along just fine. I've often wondered if the latest greatest super gun oil isn't simply repacked engine oil or something similar anyway. How would a guy know.......
Sent from my SM-G930VL using Tapatalk
I'm a mobil1 fan. I've seen it make more than one new custom 1911 run before the manufacturer recommended break in was over and they wouldn't run before hand
full chizel
¯\_(ツ)_/¯
5:31 AM
USofA
Thats my buddy Max in the pic. He’s a 16 month goose huntin’ machine. I worked with him a little bit with decoys and he picked it right up. My buddy has a 2 year old Black Lab too that he paid $3500 for with all kind of training. Max hits the water before he does and beats him to the goose every time. He gets so pissed:risas3:
Deets066
AKA Deetsey
5:31 AM
I use Lock-eez to coat the bore of a clean barrel and also on bolt and carriers. Any oil will due to wipe down the exterior. The lugs of my bolt guns get a thin layer of shooters choice grease.
I shot trap league with and old timer that used grease on moving parts. It works good as long as you can get a thin layer and don’t have a lot of excess.
Normally I clean with hoppes 9, cost with rem oil, and have a heavy synthetic oil called super lube for moving parts.
WD40 isn’t bad stuff if you get it in a spray bottle or bulk, the propellant in the aerosol is bad chit for raw metal.
Ronaldo
4:31 AM
Eastern Iowa
Grease works great as a lubricant, for sure, but not in a gun that is used in cold temps.
kingOFgEEEks
5:31 AM
Tioga County, PA
Rem oil for post-woods wipe down (spray on a silicone impregnated rag, gently wipe everywhere I touched, to get the fingerprint oils off).
Hoppes oil for the moving parts that need a dab after cleaning.
I only have bolt, pump, and single shot firearms, so while lubrication is important, it's not as vital as it is on a semiauto or lever gun.
