Gravedigger
- 5:19 PM
- Jun 23, 2017
- Fair Hill, MD
did you install the hl supply crank in the case? is that the one in the pix above? did you use the tool?
11.71 is a little small for the OD on the clutch side... 11.9 is the spec I think for proper m12x1.0 threads.
Yes I installed the HL Supply crank using your tool and everything went very smooth. The picture is the new crank in the case.
@Mattyo
