furb
- 1:18 AM
- Nov 8, 2017
- Womelsdorf
So I got the wood stove notice from homeowners three years ago. No solid fuel stoves in garages. I ended up getting a 10000 watt 34k btu electric heater. It’s okay but I wanted something more efficient and with air conditioning. I put a Friedrich 24k mini split in. It’s the new 454 refrigerant model if that makes a difference. Some first impressions… The duraheat drew about 40 amps on high. In three hours I could bring the temp up about 15 degrees. This varied by it was a good rule of thumb so I could time when to turn it on vs when I was going to go out. The new unit took nine hours to raise the temperature 16 degrees with the help of the the duraheat on low. The mini split runs about 12 amps. The mini split does push the heat around more so it probably isn’t the best comparison. To summarize if you want quick heat and don’t want to run heat 24/7 a heat pump isn’t the solution I hoped for. I’ll be keeping the duraheat hooked up. It has a freeze protection mode that maintains between 40 and 46. It had the garage at 35 in that mode. I need to go out with a thermal imaging camera and see if it is 40 by the temp sensor or if there is an issue with it.
