Fuel stabilizer
Homemade
10:34 AM
Wisconsin
What fuel stabilizer do you use? I try and use non ethanol fuel, but still have carb issues in some 4 stroke and 2 stroke. Seafoam, stabil are the two I’ve heard of and never really had smoking gun evidence on either that they would save me from fuel related issues.
Powerstroke Cowboy
8:34 AM
Montana
Seafoam is what I use. I've had gas in a mower that was almost two years old that ran okay, it could of ran better though. Is it a good idea? No, but it still ran. For me, I like it since I can put my saw on the shelf for 6 month or more. It'll still start and run. It doesn't take much to mess up these little carbs. I also run ethanol free gass.
SimonHS
3:34 PM
Yorkshire, England
Briggs & Stratton Fuel Fit for me. I never have fuel related starting problems with 2 or 4 stroke engines - mowers, strimmers, chainsaws.
Clarkbug
10:34 AM
Northeast
Startron is what I have been using for years, along with ethanol free fuel. Has worked great for me, especially in things that tend to sit like the generator or snowblower.
GMB74
10:34 AM
Vermont
The "best" fuel stabilizer is an issue almost as contentious as what 2-cycle oil to use.
They all make pretty amazing claims about what they can do to "cure" fuel problems.
Keeping your fuel can sealed to prevent condensation, not using ethanol fuel, and not letting the fuel sit around any longer than necessary are just as important as what stabilizer to use.
I have seen customers who claimed to have used a name brand stabilizer and they still had water and corrosion problems.
I have used Star-tron with good results.
Ftlaud Addict
OPE Member
10:34 AM
Fort Lauderdale
Switched from Stabil to Startron. Had fuel go bad using Stabil once. I always use non ethanol fuel. No issues so far and can last 2yrs. I usually put it in my vehicle after 1 yr and rotate jugs as needed. I keep a larger than normal amount of fuel in the shed for generators.
cescarbrough
Active OPE Member
9:34 AM
Kansas, USA
I recently heard of, and started using something called Pri-G. It claims to be able to rejuvenate old fuel as well as keeping new fuel good indefinitely. I have not been able to find anyone, or any site to discredit this claim.
They also have a diesel version.
Kiwioilboiler
346 Pic Examiner
2:34 AM
Marsden Pt, NZ
Another loyal startron user here. It works great especially for things like generators which tend to sit for long periods between usage. I’ve been using it without fail for probably 10 years or so now.
This one Bradasaurus?
GMB74
10:34 AM
Vermont
Stem
Professional Cup Stacker
10:34 AM
Pennsylvania
I've had good luck with Star-Tron & Lucas Fuel Stabilizer, but I also use Non E fuel in just about everything since the Sheetz 3 miles from my house sells it.
Woodpecker
Sassy Madam
10:34 AM
bucketofguts
10:34 AM
north carolina
My saw tech 83 years old has used it for years. I think he is a seafoam loyalist and one of the fancy 2 stroke oil at 43:1 and he ain't going to change. I think he uses Lucus synthetic blend. He was a snowmobile champion up North back in the day. In the snow and on the drg strip. Can still pull my 1990 262xp like an 026.
mainer_in_ak
6:34 AM
Interior Alaska
I just switched this season to startron in everything. The marine stabil I was using, it does the same thing that the red stabil does:
Settles into the bottom of carb bowls or filters, on equipment that sets for a while. Just got my atvs pulled out for spring, and there's this blue-green "stabil booger" in the filters.
mainer_in_ak
6:34 AM
Interior Alaska
Been running the lucas for 2 years in all my saws. 32:1, no problems. For 5 gallons of gas I run 20 oz lucas, 2 oz startron, 5 oz mmt. We only have 90 octane up here in Alaska, so the mmt gets the gas close to 91 octane.
hotajax
10:34 AM
Eastern PA
Been using Pri-G for years, and your premixed fuel will hold up for two years or better. I'm a true believer.
FergusonTO35
10:34 AM
Boonesborough, KY
I'm currently using Sta-Bil marine formula at a full ounce to each gallon. I have also used Star-Tron with good success, can't remember ever having any problems that I suspected were from ethanol and/or stale fuel. If pure gas was available locally I would use it, but the nearest place is 20 miles away. I use BP premium in my 2 strokes and it seems to do well.
jakethesnake
I Am The Snake
10:34 AM
Here & Now
Like 50:1 type ratio. Or maybe a bit leaner. Haven’t had carb related issues.
farminkarman
I like the red & black ones
9:34 AM
Neenah Wisconsin
I put 2 stroke oil in my 4 stroke small engines. Been working for me for years.
Assuming you mean that you put it in the gas? I started putting mix oil in all my cans because I don't trust the kids to not straight-gas my equipment. So far it doesn't seem to bother my utility vehicle or my push mower....the lawn tractor is diesel, but I add mix oil to it as well.
