- 9:57 PM
- Feb 5, 2016
- Here & Now
I add more oil to my 55 and it runs out the muffler. Still runs great. I be confused too. I’ll just stick to what works fee me.
If one drops the oil ratio say from 50to1 to 32to1 and leaves the carb tuned for 50to1 the saw will be lean and starve for fuel. Retuning the h speed to richen is necessaryYes, opening the H will ensure enough fuel gets in to keep
the engine running cool enough, and we all need to ensure this.
But in doing so there will still be more oil in the system, which is
fine as long as it does not interfear with the plug and spark screen
too much, and over time it will clog the rings.
My own feeling is, ensure you have enough oil in your mix,
ensure you up the H screw to keep your engine cool.
Tuning in my eyes will cool down a saw,
where adding oil will lubricate it.
As long as we know how one effects the other, then we can set up as
we see fit.
I believe our friend @Moparmyway said it best.If one drops the oil ratio say from 50to1 to 32to1 and leaves the carb tuned for 50to1 the saw will be lean and starve for fuel. Retuning the h speed to richen is necessary
I see the point there just seems like in my real world experience it isn’t alwaus the case. Should be I guess but my 272 and 55 seem to not care or change tune much if any. My 346 will react to any change dramaticallyIf one drops the oil ratio say from 50to1 to 32to1 and leaves the carb tuned for 50to1 the saw will be lean and starve for fuel. Retuning the h speed to richen is necessary
In that case u were way rich to start at 50to1. Most folks think adding more oil to the fuel makes the saw richer which isnt the case if it isnt retuned or it was already on the extreme rich sideI see the point there just seems like in my real world experience it isn’t alwaus the case. Should be I guess but my 272 and 55 seem to not care or change tune much if any. My 346 will react to any change dramatically
So how much difference will it make from 50-1 to 40-1?If a saw is tuned spot on for 50to1 and and the orfice is letting just enough fuel through and tuned correctly and not on the rich side, adding more oil molecules to the fuel without tuning isnt gonna let the same amount of fuel through the orfice tuned for 50to1, hence the saw will run leaner
No I think they are right. They have a very special made saw, that is what is needed for that saw to run right. The oil won’t burn saw up. Heat is what burns up saw. That comes from lean tune on saw not oil in mix.Now then just a simple question .If those who advocate running mixtures such as 50 to 1 ratio explain how most chainsaw racers with 3 to 5000 dollar racing saws run much richer mixtures and why they do it .Are they wrong ?
Im really not sureSo how much difference will it make from 50-1 to 40-1?
Some here have said no need to retune. I think a lot of people tend to tune rich anyway. My be because of that. How many of you retune for this?
No they are not wrong, they are 100% right.Now then just a simple question .If those who advocate running mixtures such as 50 to 1 ratio explain how most chainsaw racers with 3 to 5000 dollar racing saws run much richer mixtures and why they do it .Are they wrong ?
Not completey true, I have a saw that when fourstroking has less than 400 rpm to go before it hits the limiter.Speaking of tachometers .I get a kick out of Rich D of Oregon who has "shop talk" on some of his e-bay deals .Using a tach before he makes a demo cut on whatever he tries to sell .It's all for show and doesn't mean anything but eyewash .Tachs are nice to check something but anybody who knows anything relies on the good old ear --unless they are stone deaf ---
In all reality this rarely happens because most saws are set on the rich side and the change is very, very slight. The effect of a twenty degree swing in temperature has more impact than a miniscule change in oil ratio.If one drops the oil ratio say from 50to1 to 32to1 and leaves the carb tuned for 50to1 the saw will be lean and starve for fuel. Retuning the h speed to richen is necessary
