GCJenks204
"Special Buns"
- 11:20 AM
- Dec 31, 2015
- Winnipeg, MB
M-Tronic FTW!!!
Yes it will be leanIn doing some reading, and thinking outloud, I would just like some feedback on this. Not sure if anyone else ever wondered about the same thing.
Does one need to retune a carb based on fuel mix ratio? For example, If I had a carb tuned for 40:1, then I decided to try 32:1, do I have to retune the carb for the new mix ratio? Or will it run ok based on the previous tune?
If we checked our saws wfo for a second every 5 minutes of cut time listening for a 4 stroke we'd never burn up a 2 cycle engine. If it has oil and it's 4 stroking, I don't think they'd ever burn upThanks guys. I usually most always tune on the heavy side anyway.
And I most always check from tank to tank as well. Sometimes on bigger trees, cut to cut. Just wanted to reaffirm that I was on the right track.
I usually run a fatter mix as well. Probably overkill, as I had a Stihl 029 for over 20 years that was given heavy usage and piston and cylinder looked new when I sold it a few months back. [emoji106]
No, the more oil in the mix, the less fuel, so you are already running lean,Nice topic,
I think sometimes I need to hide my orange screwdriver and just run it.
My normal tune is a touch fat usually.
I have wondered the same thing about mix ratio. The idea being if I run more and better oil can I lean a saw out more and keep it protected?
I tested 46:1 and 50:1 in the same Echo CS -501, and the 46:1 stopped her fourstroking.If we checked our saws wfo for a second every 5 minutes of cut time listening for a 4 stroke we'd never burn up a 2 cycle engine. If it has oil and it's 4 stroking, I don't think they'd ever burn up
If you were tuned properly, and did not retune after switching mix ratios, your statement may be correct. But once retuned, the theory of 50:1 being richer than 40:1 goes out the window.No, the more oil in the mix, the less fuel, so you are already running lean,
and to further lean it will cook it.
Adding more oil to the mix to lubricate the saw is not as good as running
the saw on 50:1 and have her rich, I read somewner that this was tested
and saws wear less and run cooler on a slightly rich mixture as opposed
to saws that ran with more oil in the mix.
If you study it, heat is the real killer in a saw engine, and do all you can to
keep it cool especially under heavy loads, sharp chain, take a little more time
and plenty of fuel to run her cool.
A saw tuned for high altitude will also run too lean when brought to a lower
altitude, and this alone will cook your saw too.
Its about knowing what needs doing for a given situation.
I don't know about which burns hotter, but I agree with your statement as long as your screwdriver has compensated for less fuel getting to the engineI would think 40:1 would always run cooler than 50:1 due to more oil. Taking that one step further, I would think 32:1 would run a bit cooler than 40:1. Oil doesn't burn as hot as fuel, thus keeping engine a bit cooler.
Am I wrong in my theory?
Spark plugs are cheap!That is my motto. If its fat, even too fat, it will never blow. Lol
Yes, the only thing changed was the ratio of oil in the mix, no retuning took place,If you were tuned properly, and did not retune after switching mix ratios, your statement may be correct. But once retuned, the theory of 50:1 being richer than 40:1 goes out the window.
At 32:1, and tuned properly, everything inside the saw has more lubrication and will last longer. Ive seen 2 year old strato saws with bad bearings already from being run on 50:1. Never again
Oil has more calorific value and does burn hotter.I don't know about which burns hotter, but I agree with your statement as long as your screwdriver has compensated for less fuel getting to the engine
Hi RI ChevyWe may have to agree to disagree on your post content this time.
Send the saws my way, I'll gett'em 4 stroking for you on 32:1 and 36:1. [emoji106] [emoji2]
Until you open the H screw to compensate.....Oil has more calorific value and does burn hotter.
We all agree that if we don't put enough fuel in the engine
it will also run hotter, now combine the two, for that is in fact
what we do when we up the oil content.
Some engines are good with this, some don't take it well at all.
