Fuel line swap thread
Cut4fun
Redneck Chainsaw Repair
8:51 AM
Ohio
OK. The inside diameter of the Echo Fuel line looked much larger than the inside of the Husqvarna squiggly fuel line.
3mm ID and works perfect. Also makes good impulse line on other chain saw makes with the 6mm OD and the 5MM OD can be used too.
Here it is being used for impulse before cutting down.
Mattyo
Youtube speciawist
8:51 AM
Farmington, CT
remember, for a lot of husky saws, the issue is OD because you MUST get a tank seal with the line, there is no grommet ... to the OD is crucial and tygon is either too narrow or too heavy
8:51 AM
Jeeesh. A tough one there.
Mattyo
Youtube speciawist
8:51 AM
Farmington, CT
husky line is very specific... 7/32" ... .218" ...which is around 5.5 mm ... problem is, I can't find any manufacturers of 5.5mm line... just 5 or 6mm.. annoying for sure. 6mm is near .24" 1/4" is .25 of course... which is actually too big
radio
8:51 AM
SoNH
Yep, OD is critical with the huskies. The Tygon .211 OD x .117 ID line fits perfectly.
Cut4fun
8:51 AM
Ohio
If your working on your own saws or with owners permission. Remember all it takes is a drill bit to open that plastic hole up. ;)
Learned this from the poulan board on my site by guys opening that tiny hole so all 3 lines are the same size.
Cut4fun
8:51 AM
Ohio
jake wells
no longer here
7:51 AM
ky
I use echo or stihl line prefer them over knock off or the squiggly Husqvarna line.
the echo is a little cheaper than the stihl line but both hold to ethanol fine.
Husqvarna line wouldn't be bad if it would hold up to ethanol.
8:51 AM
I've done several 371 372 and 288 with the echo bulk 5mm line tight fit no leaks. I know what you mean several saws ive tried tygon on leaked because it was a tiny bit too small coming from the tank.
8:51 AM
The line i bought. 50 feet from amazon was supposed to be echo oem 5mm but it came in a rotary box so i don't know what it is but I'm on my second box in four years and i like it.
Mattyo
Youtube speciawist
8:51 AM
Farmington, CT
fairly slow.... I didn't get much done to it this summer. I'm much better at milling the wood than I am as a carpenter, so I'm likely going to hire someone to help me finish it, for an ambition boost if nothing else lol. I'll eventually post an update video on the property, maybe before winter so everyone is up to date. thanks for asking!
Majorpayne
7:51 AM
Southern Illinois
I think @griffonks talked about drilling and using a grommet but don't remember the particulars.
