Fruecrue 660 build thread
10:11 PM
Mine had the same parts left over. It's just duplicates to stuff that came pre-assembled. Other than one tiny o ring. It's smaller than the one behind the chain tensioner and the one behind the oil pump
10:11 PM
Had 1 more pic after some run time.View attachment 74154Noticed in Kevin's build thread his top badge was labeled, mine is a blank slate.
Might have to come up with my own slant eye 660 logo.
Wanna trade? That oddball ms660 font is crap. I'm thinking carb cleaner
Fruecrue
certified hand catcher
10:11 PM
Alden NY
Na' I'm digging the blank slate. The possibilities are endless.
Seems to be quite a few differences from kit to kit.
I'll trade carbs with you. Mine has a bent high screw and it takes some serious intent to move the idle adjustment screw.
10:11 PM
No thanks. I'm a 1%er with the carb that actually runs and tunes well.
Fruecrue
10:11 PM
Alden NY
Anybody know where the metering lever is supposed to be set on the Chinese carb?
Mine is about midway between the lower flat area and the gasket mating surface on the outside edge.
Note the wonky H screw in the pic.
10:11 PM
Level with the lower body. But they have a habit of sending "universal" springs that may or may not ever work correctly. Usually have to clip off a few coils to get pop off pressure down
10:11 PM
where does it pop off now ? and how long is the tit on the diaphram some carbs set up like that you have to adjust for the diaphram
Fruecrue
10:11 PM
Alden NY
I haven't measured pop off or the titty. Probably won't have a chance for a while.
Wonkydonkey
Plastic member
3:11 AM
Sussex, UK.
"Pop off" I understand, but Titty "wtf" lol, I don't know and hope that someone says... Other wise it will just be a wet dream ...
10:11 PM
On the inside of the metering diaphragm there's a metal ring with a bump on it. That bump (tata) pushes on the lever
