T.Roller
- 11:54 AM
- May 11, 2016
- Southeast, TN
Not if it's class 2 or 3for build off it has to use a aftermarket carb
Yup, I need to get the degree wheel on the cross cylinder. If it needs machine work, I'll class up and go oem on carb, flywheel and coil.Not if it's class 2 or 3
I've decided to go class 2. I'm using all the box parts except the wrist pin bearing unless others are uselessYup, I need to get the degree wheel on the cross cylinder. If it needs machine work, I'll class up and go oem on carb, flywheel and coil.
the far right o ring im not quite sure right now
Wanna trade? That oddball ms660 font is crap. I'm thinking carb cleanerHad 1 more pic after some run time.View attachment 74154Noticed in Kevin's build thread his top badge was labeled, mine is a blank slate.
Might have to come up with my own slant eye 660 logo.
No thanks. I'm a 1%er with the carb that actually runs and tunes well.Na' I'm digging the blank slate. The possibilities are endless.
Seems to be quite a few differences from kit to kit.
I'll trade carbs with you. Mine has a bent high screw and it takes some serious intent to move the idle adjustment screw.
Level with the lower body. But they have a habit of sending "universal" springs that may or may not ever work correctly. Usually have to clip off a few coils to get pop off pressure downAnybody know where the metering lever is supposed to be set on the Chinese carb?
Mine is about midway between the lower flat area and the gasket mating surface on the outside edge.
Note the wonky H screw in the pic.
I haven't measured pop off or the titty. Probably won't have a chance for a while.where does it pop off now ? and how long is the tit on the diaphram some carbs set up like that you have to adjust for the diaphram
Always......ALWAYS....measure the tittyI haven't measured pop off or the titty. Probably won't have a chance for a while.
On the inside of the metering diaphragm there's a metal ring with a bump on it. That bump (tata) pushes on the lever"Pop off" I understand, but Titty "wtf" lol, I don't know and hope that someone says... Other wise it will just be a wet dream ...
