Funky sawman
Pony Power
- 5:49 PM
- Feb 10, 2017
- North idaho
You gots yerself a great saw to build there. No better model that a 660 066 to learn the in's and outs of saws
Cant really feel any vertical play, no. Only movement is I can slide it to the side a tiny bit as shown in these two pics. One of them you can see the bearing on the right side, then I slide it over and you can see the bearing on the left side. That normal?The big end bearing of the crank isn’t replaceable, right. Still hard to say for sure based on that vid above. Does the shaft have any vertical play if you lift it away from the lobes? There’s a needle bearing in there that needs to be inspected.
Btw, what’s the two saws you got under your bench ? 1 looks like a 261![]()
It’s normal to be able to move the rod right/left within spec, yes. Excessive movement or play is bad, though.Cant really feel any vertical play, no. Only movement is I can slide it to the side a tiny bit as shown in these two pics. One of them you can see the bearing on the right side, then I slide it over and you can see the bearing on the left side. That normal?
If I think what your referring to,, it’s not a problem
Edit add pic for reference
When you took the piston off, did the wrist pin and bearing look ok?
Thank you Sir! This saw was my first ever that I bought brand spanking new so it has sentimental value for me. I only used it for a year myself but it ran perfect and I loved it with my 36"bar.Nice project.
