First build help!
Dave pulsifer
Active OPE Member
12:45 AM
Skokomish
I'm building my first saw. Makita 20190112_223314.jpg 6401 to 7900 I got the piston cylinder of the bay from dandrikorp. It's a aftermarket cylinder not oem. I will try to get some pics up.
Dave pulsifer
Active OPE Member
12:45 AM
Skokomish
Cleaned up the ports and a little extra. Any help opions, suggestions?sent my carb to poleman to do his magic also!
Dave pulsifer
Active OPE Member
12:45 AM
Skokomish
It's going to be a work saw I cut 25 cords on average sometimes more.
Dave pulsifer
Active OPE Member
12:45 AM
Skokomish
I took the carb off to send to poleman,so I cleaned up on exhaust port and intake. It was used only three or four tanks of gas since I put it on new.
smokey7
3:45 AM
Detroit
If I understandd correctly this is a aftermarket top end kit? I'm very interested it's port timing numbers stock. What brand is the kit? How do you feel it's quality compares to oem. From what I can see it looks pretty dang good.
Dave pulsifer
Active OPE Member
12:45 AM
Skokomish
Got it off ebay,dandrikorp.the greek! It's aftermarket cylinder. So far so good I'm not sure bout the numbers me being a rookie but
Dave pulsifer
Active OPE Member
12:45 AM
Skokomish
He's got a big bore 54mm. And the 52mm.I got.
