Experimenting on a Saw...
4:51 AM
Iam loving this and have you looked a centrifugal super charger were the carb is in a box on top of the intake
XP_Slinger
They’re Just Saws
5:51 AM
Central NY
I think whats killing it is the pressure is making the fuel/air do 2 things. 1st...the "boost" is doing a u-turn in the crank case while the intake is open, it's the only place it can go. 2nd...if there is any trapped pressure once the intake closes, the rest of the fuel is being blown out the exhaust
XP_Slinger
They’re Just Saws
5:51 AM
Central NY
What about replacing the decompressor with a barb or something. Then you could use an air compressor to put the boost where it belongs...in the chamber. Would somehow have to time it to only boost once the exhaust is closed. Getting extra fuel would still be an issue. OR...Maybe a reed valve would let you pressurize the case?
Simondo
10:51 AM
UK
Exhaust gas driven charger becomes a reactive thing to engine rpm.. faster the engine ..faster the turbo... put fuel in that flow and "Bang"
I would have thought you need to go "Passive/reactive " on the air charge then you can burn more fuel.
I think :D
