Excessive carbon buildup
farminkarman
I like the red & black ones
7:31 AM
Neenah Wisconsin
Clean off the carbon, use the rest of your Stihl premium oil as fire starter or give it away. Then get yourself a better oil...almost anything is better than the Stihl silver bottle. Everybody will have different opinions on what is good and what is bad...I personally want more oil (32:1) I have found several oils that I can run at that ratio without carbon buildup. Amsoil Dominator & Echo Red Armor are high on the list but expensive. I ran almost 10 gallons of mix with Walmart brand TCW3 @ 32:1 through my string trimmer this summer and there was no signs of buildup when I pulled the muffler off this fall. Bottom line, Stihl Ultra = your problem.
Woodpecker
Sassy Madam
8:31 AM
I’ll mention another budget option that has done well in testing. Castrol Go 2t although it’s an old school Dino based oil.
Woodpecker
Sassy Madam
8:31 AM
I was going to mention that one too, but I haven’t used enough to vouch for it’s cleanliness
Dominator is about all I’ve used for the last couple years. Before that was Schaeffers 9000 and before that was dolmar synthetic. I used echo red armor before the dolmar when I switched from Stihl silver bottle because it started to give me headaches, and I saw what a mess it made of a saw I tore down. I liked all the oils above except the Stihl.
I mentioned the Castrol go 2t because of the shooter of the eggs testing though. I trust Steve and wouldn’t have any problem running that or in a pinch the Walmart stuff. I don’t typically like Walmart for personal reasons, but you aren’t the only one I’ve heard good things from about their oil.
Ford3000
1:31 PM
Echo manuals warn you, they say occasionally take the muffler off and scrape the carbon out with a screwdriver.
I will read the next manual I get with a saw, instead of using it to light the fire.
B440
8:31 AM
Thompson, CT
too much piston wash. I would tune leaner if possible. Look at piston wash pictures.
lohan808
8:31 AM
Georgia
Another oil discussion?!.....
