hotajax
- 3:53 AM
- Dec 10, 2020
- Eastern PA
Echo SRM 225 a bear to start. Looked at parts diagrams, it shows a single gasket between the carb and the body of the trimmer. But when you click on the link for the gasket part number it says you need 2 gaskets. Huh? Do you know which is correct? Is there a gasket between the air filter and carb, and then another gasket between the carb and the cylinder? Thanks in advance.
