Echo SRM 225 Gaskets
hotajax
3:01 PM
Eastern PA
Echo SRM 225 a bear to start. Looked at parts diagrams, it shows a single gasket between the carb and the body of the trimmer. But when you click on the link for the gasket part number it says you need 2 gaskets. Huh? Do you know which is correct? Is there a gasket between the air filter and carb, and then another gasket between the carb and the cylinder? Thanks in advance.
mbret2004
3:01 PM
NEK, Vermont
If you look at your models parts breakdown it will show the gaskets and where and how to position them. Sounds like you need a gasket between air filter housing and carb, and a second one between the carb and engine block. Reference the proper Echo parts diagram. I believe they are on Echo's website. Good luck.
hotajax
3:01 PM
Eastern PA
Thanks, M. Where is NEK Vermont? We have family in VT, but I never heard of that region.
