ECHO Echo, Echo, Echo
Woodtroll
6:21 PM
Mtns of SW VA
Ok, I think I've figured it out! See the flanged bushing inside the oil pump drive?
It is supposed to have the flange on the inside!
If you install it with the flange on the outside, the flange will contact the clutch shoes, thereby also turning the clutch drum! I reassembled it, and now it idles down to 2800 rpm without the chain turning. I don't remember ever taking that part out of the saw, but maybe I did at some point. Never too old to learn something new!
Glad that you figured it out, and that it was a cheap fix! :)
STOVE
6:21 PM
Eastern NC
I guess I’m a bit of an echo fanboy of sorts. All of my small engines outside of a hand me down homlite blower are echo.
I used my 590 yesterday to clear a large oak limb off a tractor. It’s amazing how easy all my echo stuff cranks. The carb is a little finicky but that’s what you get when you mess with stuff instead of leaving it factory.
I’m sure my 590 is not a compression monster but I can’t recall the last time any of my stuff took more than 3 pulls.
STOVE
6:21 PM
Eastern NC
I wish that I had bought two CS-400 saws, I'd like to have one in my collection!
Not that I need another saw...
They pop up used around me all the time. Cannot seem to find any decent older husky or Stihl stuff to rehab. But loads of smaller echos.
There is a parts saw on my dealers back room shelf I thought about grabbing just for teardown practice
FergusonTO35
6:21 PM
Boonesborough, KY
They come up on Fleabay all the time, that's where one of mine came from. FB Marketplace, Craig's List, and pawn shops are also good places to look.
STOVE
6:21 PM
Eastern NC
Getting ready to re-do my 590 muffler. My first one was cool at first, but I cannot take the sound anymore. It’s poppy, and just too much. Going to keep the top deflector mod that everyone does but change up the openings
Which of these three offers the best performance without terrible acoustics
Option 1 is adding openings to the side walls similar to the below photo I found in another thread
Option 2, west coast power port 7/8 size. On the clutch side, similar to another members photo
Option 3, west coast power port 7/8 size on top, where I have colored in red
EFSM
5:21 PM
Extreme southern IL
I have only done option 1 on those saws. The other option is to start with a 620 muffler; they have a much more open inner baffle and flow much better stock.
STOVE
6:21 PM
Eastern NC
Option 1 is free, the other two will cost either $45 if I go west coast 7/8 route. Or go with a @Red97 cut it yourself and figure my own attachment.
Already have $65 in the muffler, hard to stomach another $45. I just need the flow without the poppy sound
STOVE
6:21 PM
Eastern NC
Getting the 590 dialed in. Dukes chain, sharpened a little too aggressive from what I have read. Timing advance, MM, carb nozzle fixed, gearhead air filter seal
Feels like I’m hitting the limiter , still training my ear. Mid 1200 with the cheap Amazon tach
STOVE
6:21 PM
Eastern NC
Is she turkey bacon, regular bacon, or fatback?
mainer_in_ak
2:21 PM
Interior Alaska
Youre not anywhere near the rev limiter. Too much ignition timing. I can hear it in the cut, cackling. If it's one of those goofy gear head offset keys, take it out and use your original flywheel key. With a pair of calipers, only remove .015 off the key.
Make sure the gas is fresh stuff, 90 octane or better mixed at 32:1.
STOVE
6:21 PM
Eastern NC
It is the gearhead key, going to have to track down the original. I was more so trying to get the high setting correct.
EFSM
5:21 PM
Extreme southern IL
If you’re looking for top performance, the OG cs-600p had the farthest advancing coil of any saw in that chassis. There is no exact rev limiter on your saw’s coil—it simply retards the timing drastically past a certain point.
STOVE
6:21 PM
Eastern NC
Sound is so much better however I did a *s-word job with the second nut. There is a little gap where it distorted the muffler trying to tighten it up. It’s wedged in there pretty tight however I fear there is some heat escaping the distorted hole
Also concerned about the clearance between deflector and case. Might be stuck with the loud muffler.
It’s a shame because the sound is so much more appealing.
