- 1:54 PM
- Mar 13, 2022
- Interior Alaska
Joe, I'll tear em down and measure the transfers, squish and compression. I'll post up pics of the cylinders. I'm curious about this too.
Cant get them in Ireland at all, they had them when they came out, but they probably couldn't chargeWell I finally got a 4910. It's very pleasant to run, quiet, easy to start, light and cuts little stuff pretty good with the 325 chain. I'm going to run it awhile like this before I make any changes if I do decide to make them.
Echophiles...should be easy question on the 620? What's the deal with 70 drivers on 20"? Is this the Echo bar and can be changed by using different bars, or is it the way the bar mounts. Can I run 72 drivers on 3/8?
Thank You
Thank You
It is the Echo bar, you can change to 72DL only if you get a bar that is advertised to fit 72dl on a Echo.Echophiles...should be easy question on the 620? What's the deal with 70 drivers on 20"? Is this the Echo bar and can be changed by using different bars, or is it the way the bar mounts. Can I run 72 drivers on 3/8?
Thank You
4910 was never present outside USA. 490 - yes.Cant get them in Ireland at all, they had them when they came out, but they probably couldn't charge
enough for them else they would have to put the prices of the CS501 up even more to leave a gap
between it and the 4910, sad, as its lighter than the 4510, and that is why I won't buy a 4510, same
weight but less power, makes no sense at all.
I saw the 4910 saws advertised on the sites in Ireland, but never seen one here at a dealers.4910 was never present outside USA. 490 - yes.
If you hate 4510 for 300 grams maybe it’s upcoming 50cc “twin” 4920 will be a bit more interesting?(on the bonus side there are spring AV’s with ~30% less jiggle?)
I had 3 CS501 saws, they were well built, I had a Shindaiwa 490 before them, I liked it more,
think it was 490, wish I had of kept that one, it looked like this,So what is the 4920 in aid of, is it a 50cc saw, that would make three of them, the 501, the 4910 and the mentioned 4920.
Its not just the 300 grams, its the lost power too, so I would rather have the 300grams more for the extra power.
I see there is a CS4010 available in Ireland, is that saw available in the US, I don't think I have read much about it,
must have a look.
I know what the Shindaiwa 490 is, to me they were a better saw than the CS501, which buzzCS-4910 is just a 501SX with plastic handle & rear grip, simpler spark plug connector, stainless steel sprocket guard plates and laminated bar. US-only, regardless of online ads.
Shindaiwa 490 is actually an older thing derived from 488 (produced from 1988) while the 501 history looks like this: 466s -> 452s> CS-490/500 -> CS-501/4910.
As I mentioned - 4920 is a reinforced twin brother of CS-4510 with bigger bore & stroke. Slightly better curve than CS-501 but basically the same power range with every other feature being same as CS-4510.
CS-4010 is a 40cc thing replacing CS-420 so it is just offtopic in this case![]()
through the handles, I had three, all the same buzz in the handles.
I commented about the 4010 as I know nothing about it, and you seem to know
about the brand, if it upsets you that more than one saw is being discussed
then ignore my posts, you seem to have some sort of complex.
You also forgot a very important detail regarding the differences between
the 4920 and the other 50cc saws mentioned, that being whether the 4920
is a clam shell or split case.
And no, please don't answer, its easier to look this up elsewhere than be
talked down to by you.
Probably some sort of misunderstanding as I definitely was not intending talking down to anyone (not English native anyway, so things probably happen).
I apologize if it sounded this way.
Also I don't really feel upset (why should I?). Not sure about the complex thing too![]()
My buddy has one, but the Echo CS750 equivalent JD.My only entry is this JD stamped Kioritz . Haven’t had it long,got it sans bar and not running , fixed the usual culprits is all it required.slow and heavy but it’s got grunt and sounds really healthy! View attachment 361493View attachment 361494
