Thesandman
- 2:24 AM
- Jan 22, 2021
- Mid michigan
Sorry. I had too. I wouldn't cut it out myself because of my previous experience. Good luck
Damn what a predicament . Sawing sounds way better than chipping.Today's chainsaw adventure:
Overflow filled my side-channel where I park my river boat. The river level came up over 3 ft in the dead of winter, because of a warm-spell. What was once dry land where my boat was 10 ft away from the ice, is now 3ft of solid ice. It even poured into the treeline.
The fkn drain plug was pulled. The boat filled with water, and froze into the overflow. Not only is the boat frozen into a ft of overflow, it's filled with at least 800 lbs of ice.
I'm undecided what to do:
Build a tarp-tent around the thing, and thaw it out with a wood stove and chip away soft ice?
Or echo chainsaw that fker till she's clear of ice? Im worried that as I cut on the inside and outside of boat I may accidentally cut the hull.
I'd focus on getting to the drain plug hole, defrost it, plug it, then build a tent and defrost the boat from the inside in a safe way.Steve, a weird deal and first time. Figured out a technique that seems to work. Cut 1 ft from boat at 30-35 degrees. Hack at the ice and it cracks into large shavings because of the relief cut. Sweep out shavings repeat.
Inside of boat: careful score marks with tip of saw, only going 2-3 inches at a time. Light/careful strikes with hatchet. The cubes break away without harming the hull.
Only about 50% cleared of ice, and arms turned to rubber, ha!
See an Echo CS680 for sale, are they any good, are they too old that
Not sure it is a 680, looks slightly different than others online do.Those were only discontinued a few years ago here and parts are very easy to find. I would make them an offer on it, I'm sure that a new CS-7310 would be like twice as much.
Not mine (I wish).Gullet, I have never seen on of those! I'd like to run one.
Question for the echo guys:
Has anyone ever encountered a factory original older orange cs or qv 6700 where it was assembled with no base gasket?
From what I seen online, a CS621 will out cut the 680 every time as they seem to rev higher,Those were only discontinued a few years ago here and parts are very easy to find. I would make them an offer on it, I'm sure that a new CS-7310 would be like twice as much.
They arent that heavy compared to other 66/67cc saws.From what I seen online, a CS621 will out cut the 680 every time as they seem to rev higher,
the only good thing is the round filter which is better, its not the same filter that fits the new 7310,
as its lower in profile, some guy mentioned he was going to try and put the filter from a 680 onto a 620 for that reason.
I might make an offer on Monday when they open again, its a heavy saw with low power, I understand it
has torque, but the majority of wood I want to cut would be better with speed over torque, not big wood.
