jmester
- 12:24 PM
- Aug 28, 2016
- VIRGINIA
You have to buy the D carb adjustment tool if it’s the same as a dolmar 7910. Cheap on ebay. I usually remove the screws with the tool and slot the heads with a dremel cutoff wheel. That way I can use a screwdriver.
Do you have a link for them. Just got the carb adjustment screwdrivers from echo and none of them fit. Either to small or to big. Got an aftermarket d but the fit is very sloppy.
