beowulf67
- 9:45 AM
- Aug 17, 2020
- Trenton, NJ
It already is, but for now it’s JDM Shindaiwa E3073SP
That color scheme is SWEET!
Dealer says, "mid-$800 range with the 24" B&C. Could not get an immediate answer, but my ?'s are can we get the 28" from the factory here and, more importantly, do we get the nice Sugihara/Tsumura guide bars.
Yes, because the titles mention working in cold conditions ( https://translate.google.com/#view=home&op=translate&sl=ja&tl=en&text=寒冷地でも快適作業 寒冷地に順応したヒ一ティングモデル )At about the 02:15 mark, is it safe to say the narrator is discussing heated handles/carburetor feature?
https://www.yamabiko-corp.co.jp/shindaiwa/products/category/detail/id=11124Do you have a link to Yamabiko in Japan?
Yes.What is JDM? Japan Domestic Market?
Yes, for Japanese market the heated version is an option (so is for their 43cc pro chainsaw that will be also released in Europe as 4310SX, 50.2cc a.k.a 501SXH). Notably they have carburetor heating element which is not so popular or needed in Europe.At about the 02:15 mark, is it safe to say the narrator is discussing heated handles/carburetor feature? I see an external switch in some of the camera angles.
The new 4310SX (JDM E3043) is then in the product lineup a successor of 452s (Echo CS-452ESX)?
Finally some competition in the "pro sub-50 ccm" class. Up to now there's only Stihl MS241 and HQ 543xp.
if there the same as the 590/620 a drywall screw works well. Turn them full counter clockwise turn the screw in and pull.Those limiter caps are a real pain to get off. Anybody have a tips or tricks to get them off?
Payed around $40 under 8 for it with 24" bar.
You have to buy the D carb adjustment tool if it’s the same as a dolmar 7910. Cheap on ebay. I usually remove the screws with the tool and slot the heads with a dremel cutoff wheel. That way I can use a screwdriver.I think they are different from a 620. This is a zama carb with single d screws. And the cap is somewhat under the screw.
Nice saw you have there, hope you get good service from it.Those limiter caps are a real pain to get off. Anybody have a tips or tricks to get them off?
