Philbert
Chainsaw Enthusiast
- 11:52 PM
- Jan 30, 2016
- East Dakota
https://www.echo-usa.com/Products/C...urce=facebook&hss_channel=fbp-133987349996072
"The CS-7310P Chainsaw is not only ECHO’s most powerful chainsaw in North America but it has the features arborists and loggers need to tackle tough jobs. Whether you're tree felling or firewood harvesting, the CS-7310P is powerful, durable, and ready to work as long as you do."
Oil Capacity (fl oz) 12.2
Dry Weight (lbs)1 14.9 without bar and chain
Starting System standard
Sprocket Cover Magnesium
Ignition System digital ignition system
Bar Type PowerCut™
Available Bar Lengths (in) 20, 24, 28, 32
Oiling System Automatic/adjustable
Handle Aluminum with Rubber Overmold
Vibration Reduction System Standard
Fuel Capacity (fl. oz.) 27.1
Warranty 1 yr commercial / 5 yr consumer
Philbert
- High-power 73.5 cc 2-stroke commercial grade engine
- 4-stage air cleaner system results in longer air filter life
- Decompression valve for easy starting
- Automatic, adjustable clutch-driven bar oiler operates only when the chain is moving to reduce oil consumption
- 19mm captive bar nuts – no chance of losing hardware
- 3-point spring vibration reduction system for operator comfort
- Aluminum handle with rubber grip for strength and comfort
- Winter operation plug has 2 positions - 1 for winter and 1 for normal conditions - to improve engine operation
Bar Type PowerCut™
Philbert
