Echo cs 510 build
Red97
3:07 AM
MI
Looks like the 3/8 lo pro and full size 3/8 were the quickest. 325 looked to be a little behind.
Woodpecker
Sassy Madam
3:07 AM
The 510 definitely feels more aggressive, probably the better limber of the 2. The 5000 just has a different exhaust tone. Cut times are similar, slightly favoring the 510.
I need to freshen the chains and try again
As for the 32, both of these saws feel really similar to the 490. I would say the 490 falls right in between. Just by feel 510,490,5000 but no longer have the 490 to compare.
Once we get @Woodpecker 501 ported we can see how they stack up.
As far as the 501 I'm game whenever you are Joe!:beer-toast1:
Both saws look and sound strong! Are either unlimited coil? Just wondering if the unlimited coil on the 501 ends up being the x factor between all the saws.
Red97
3:07 AM
MI
Both of these are unlimited, major requirement for finding a 50cc echo that could best the 490 lol.
The 5000 has the larger carb, but tiny ports. Where the 510/501 have small carb but large ports. Interesting idea echo....
Woodpecker
Sassy Madam
3:07 AM
Hmmm... Does the 5000 carb fit the 510/501?
3:07 AM
Not without some doing.. the 510/501 run a wt series carb while the 5000 uses the hda series.
Yeah that would be fiddley... bummer
You 2 got 3.5 weeks to get these rigs polished up. Only Echo that ever made it to Custer's gtg was a top handle. Chop chop
king15428
New OPE Member
3:07 AM
SW PA
I'll post the 530 pics/build here too.
Think it cleaned up good enough to use. Just a couple light scratches above the port. Only other option is a 200$ short block. This one appears to have been straight gassed. Clear fuel in the tank.
Also the intake boot was torn along with the oiler damage from chain derail.
Cylinders look really nice! What was your method for cleaning these cylinders up?
Red97
3:07 AM
MI
king15428
New OPE Member
3:07 AM
SW PA
Sandpaper on a mandrel. 80-400 grit
Thanks! Any pictures of the setup?
I'm also doing a cs510 right now that I got for free. Obvious someone fed it straight gas and the cylinder looks salvageable (hopefully). You wouldn't happen to have a spare 510 cylinder to sell if this one doesn't clean up ?
Red97
3:07 AM
MI
Just a rod with a slot in it. Slide the paper in and wrap.
No spares sorry.
