echo cs-501p stalling
eonk
Active OPE Member
2:29 PM
Wadsworth, Ohio
I recently purchased the cs-501p and used it once. It ran fine. About a month later it will start fine and cut, but when i release the trigger, it dies. it has fresh gas. Any thoughts on the problem? I cant take it back to the dealer, but if I am making a silly mistake, I would like to know. By the way this isn't my first chainsaw.
2:29 PM
Is it new or did you buy it used?
EFSM
1:29 PM
Extreme southern IL
Echo tends to set the idle speed fairly low from the factory on those saws. Try turning the idle screw up half a turn. It is located right by the starter handle on the shroud below the air filter cover.
Ed Sybert
Active OPE Member
2:29 PM
Hanover, PA
I had the same issue with a new CS4910. I simply adjusted the idle speed faster by turning the screw about a half-turn clockwise. The OP may need more or less to reach a stable idle speed. Just be sure to keep it below the speed at which the chain begins to turn.
