JRHAWK9
- 12:00 AM
- Feb 23, 2016
- Lake Delton, WI
Hi, I just bought my first Echo; a new 355T. Will probably be replacing my Husky T435. I have an EPS pipe on the way for it and I already opened up the intake and removed the limiters. My question is, those who have advanced the ignition timing, how much did you file off the flywheel key? I took 0.02" off of it and it ran like complete crap. I could tell as soon as it started it was too advanced. I went back to roughly where it was stock and left it be....for now. I may buy some additional keys for it and file them differently to try. If I do that I'll probably try taking 0.01" off of it next. What have you guys had good luck with?
Background info:
The width of the key started out at 0.117". I filed it down till it was 0.097". When I installed the flywheel I rotated it CCW up against the key and then tightened it, making sure the flywheel did not rotate. This proved to be too much, as when I put it back to the stock location, everything was fine again.
thanks!
Background info:
thanks!
