Echo Carb Limiters Question
Chainsaw
10:54 AM
Mid Atlantic USA
When you folks remove the carb limiters on an Echo chainsaw, do you throw them away or reinstall? Do the limiters serve any purpose to hold the settings in place? I’m inclined to give the liters a toss, but looking for some advice here.
Thanks!
jmester
10:54 AM
VIRGINIA
Not really familiar with echo limiter caps. But on other manufacturers I usually just trim off the portion that limits the adjustment then reinstall. I will trim new limiter caps and install them when rebuilding a carb. I think it helps to hold them. Plus keeps some of the dust and debris out.
Duane(Pa)
It's the chain...
10:54 AM
Centre County
I follow an Echo guru on yt. He puts them back on after defeating them. His reason is easier to get tuning screwdriver alignment with running saw. I had a saw that seemed to have very slick tuning screws. I always suspected they “moved” from vibration. So, the added friction wouldn’t be a bad thing in my book.
EFSM
9:54 AM
Extreme southern IL
OOOh! Today I pulled 4 off two 2511T carbs and tossed them in the trash. Guess I'll be dumpster diving in the morning.
The needles stay in place just fine with them off, but due to how small the needles are it can be hard to line up a flat screwdriver without looking. Echo sells a sleeve that fits over the screwdriver shaft that centers it on the needle, and you could do the same with a piece of copper tube. IMG_0985.jpeg
10:54 AM
If you’re talking about the red plastic caps, I pull them with a drywall screw, trim the tab off and put them back in. I’ve had a few saws sent in that have caps removed and the jets get bent from people trying to get the screwdriver lined up and they are actually too deep and end up prying on them from the side
IffykidMn
9:54 AM
Minnesota
Makes me question how many get bent just trying to get the limiter caps out.
Coupe
2:54 AM
New Zealand
If you have trouble with the jets backing off it is because the springs have
got weak. Just gently stretch the spring a tad and that will put some more
tension on the spring.
legdelimber
10:54 AM
N.C.
Don't forget the little washers and O-rings whilst you're in there.
If there aren't any, I personally recommend getting some.
Might have to look through some part lists for carburetors and try to find a size that fits.
I have seen some adjusting screws that were cross drilled (in the threaded portion) and had a plastic bit pressed in the hole, to hold the screw in place.
Echo blower PB-500 carb has the bloody things. The screw threads are left badly burred up when they do that.
The burrs tend to rip the threads out of the carb body when you turn them.
I had a post over on Arboristsite in the handheld section (I think it was)
about my adventure with that type of Mini "D" head.
Was just a blind fluke that I stumbled across the slotted head ones to replace the Mini-"D" head screws.
If there's any useful info left, It's over on AS.
Seems they canceled my membership when they changed owners or something.
And happy screw tweaking!
EFSM
9:54 AM
Extreme southern IL
There are no springs on modern adjustment needles. There is a plastic insert either in the carb body or in the screw to act as a lock.
