grits
Active OPE Member
- 12:39 AM
- Apr 8, 2025
- New Zealand
I've picked up a Dolmar PS-7300 in great condition that's only been used as a homeowner firewood saw. The oiling rate was very light, if you were being generous you could maybe say 1/4 of a tank of oil to one of fuel with the oil adjustment screw fully open and spray off the tip was very, very fine. It has a lightly used Tsumura 18" bar and everything looked clean in terms of the channels and holes but I've taken the covers off a few times and made sure. Running the saw without the bar resulted in a fairly steady rate of clean oil coming through the channel. The guide plate is very slightly dished but seems to clamp down fine with the bar on, the mating surface seems to be a fairly raw casting, not a mirror finish by any means but it doesn't seem like I'm losing much oil behind the plate. Today I worked the adjustment screw back and forth a fair bit and gave the saw a good while to run in without going into wood and it seems the rate has picked up. The tip was throwing a fair bit of stringy black globules and inside the sprocket cover is getting pretty oily, it was pushing a fairly steady trickle out the top which I'm assuming has come off the chain with that point being above the outlet. Going by this behaviour I think I can turn the rate down again but just wanted to check if my experience so far gels with others experience of the saw and their understanding of its function? What rate do you like to see in terms of oil usage to fuel on these saws?
