t4driller
Daddy Day Care
- 6:37 PM
- Feb 23, 2016
- Southwest pa
Where do you think you see transfer at? And where can I get acid from? I've always just used sanding , and this is the first I've had a problem. I'm willing to try different ways of doing things.IDK,
Guess I stand alone in thinking more transfer needs to be removed from your jug.
I use acid and sanding. The problem I've found with sanding alone is that you can polish some of the transfer and not see it.
I'd degrease the jug well, apply acid carefully with a Qtip, and see if you've got a lot of bubbling going on there.
Sent from my SM-G925V using Tapatalk
