Dolmar 64xx/73xx/79xx series, smurfs and solo 665/675/681 thread
Lightning Performance
11:42 AM
East of Philly
The same part on a husky or stihl is metal. Not sure why they made it out of plastic. It’s very easy to replace and inexpensive though. However it’s something that shouldn’t be a problem in the first place... Metal would have been better.
If the pump jams your plastic part will give up first.
11:42 AM
Make sure you copy the offset on the white adjuster if you decide to make them, not the black one. White one has more offset, puts out more oil. I had to increase the ramp on the oiler piston when I used the black adjuster to get a full tank of oil used for a tank of gas. You could probably play with more offset on the metal copy, maybe .010 more offset would be nice. Also, the oem adjuster nub has a slightly rounded end, not cut flat. If you made the end flat on the metal copy it would probably dig/wear more into the piston ramp over time.
11:42 AM
East of Philly
Close up pics
mettee
8:42 AM
Arizona
Yes, its kinda a full system, mix of the best of both worlds for filtering and performance(K&N with pre) and a huge stack in the HD housing. Have to use the HD housing to fit it.
stranter
4:42 PM
UK
Wonder if anyone can ahead some light on this Makita 7900.
Colleague heard a nasty noise while pulling over his saw. Long story short I pulled the cylinder off to discover it had broken at the base! Luckily I had a spare lying about so tried to rebuild, but discovered the crankcase had cracked when I pressure/vac tested it. It appears that the force of the cylinder breaking had also cracked the case.
I ported the original cylinder, so conscious it could be something I did wrong, although never had this problem before. The build was base gasket delete and the lowers were case matched and blended, intake and exhaust were widened and smoothed, but no timing change (other than BGD). I torqued down the cylinder bolts with locktite to spec also.
Any ideas what has happened here? Could it be a casting flaw?
stranter
4:42 PM
UK
How were the old bearings when you pulled it apart? Maybe they gave out and allowed the piston to hit the band?
The bearings were perfect when I built it as only had 25 hours or so use from new. I’ll double check, but I don’t think it has more than 100 hours on now!
