Dolmar 64xx/73xx/79xx series, smurfs and solo 665/675/681 thread
11:30 AM
The above is just my personal opinion!
I do not expect that everyone agrees with me and that is perfectly fine.
Cheers 🍻
11:30 AM
Fixing my PS-7310 muffler, gonna bolt the sheet down with the remaining nut and then try drop a spot-weld on the opposite side.
Although, I think the muffler will burn right through.
No, I have no brazing equipment.
Edit:
S&S_Work_Saws
#1 Ranked Riff-Raff
4:30 AM
Salem, Missouri
A few of mine...
The blue one I'm about to start building. I got a 7910 cylinder and a solo crank for it.
I've also got a dolmar concrete Saw muffler I think I'm going to attempt to chop up and see what kind of results I can get out of it.
11:30 AM
So sad when complete idiots mangle up saws! 😢
This was supposed to be a "fell off tractor parts saw" which she is not!
Falling off a tractor does not replace 30% of the screws & bolts with non OEM.
Falling off a tractor does not result in deep screw driver marks driven between the case halves & both bearing being damaged.
Falling off a tractor does not severely bend the tubular front handle nor call for welding up the muffler.
And the list goes on as over 50% of the saw is unusable.
This is the worst I have ever seen!
Shane¹
5:30 AM
Kentucky
I hate when people "try" to work on things and make them worse than they were. Hopefully some of it is salvageable
11:30 AM
Cylinder looks OK, 50mm.
Starter assembly, clutch cover (has a crack), cylinder & AF cover, muffler (dented & welded, not modded), coil (maroon), possibly flywheel (sheared keyway), maybe carb - may be usable, but need checking.
I am also hopeful that the crank did not get fubared!
Hard to tell though with the brute force having been implemented to "break" the PH apart.
I have never before encountered a large frame Dolmar with this much operator caused damage.
So sad!
Shane¹
5:30 AM
Kentucky
So sad!
How bad is the damage to the cases can't be saved by sanding back flat? Maybe make a gasket out of thicker gasket material to make up the difference
11:30 AM
Case halves are a complete loss, no saving those! 😟
I guess they could be set up for taking porting measurements, other than that they are trashed.
IMG_20240725_180611.jpgIMG_20240725_180604.jpgIMG_20240725_173459.jpgIMG_20240725_171415.jpgIMG_20240725_171403.jpg
Shane¹
5:30 AM
Kentucky
11:30 AM
What a bummer 😞
Like literally flat screw driver tip driven between the case halves to break them apart!
I have newer before seen a saw this mangled.
And I have seen s#!t that made me refuse to even look at someone elses OPE anymore.
I f-ing don't care, buy new or take it to a dealer!
11:30 AM
This is probably the "falling off tractor" damage she suffered
Which does not explain all the remaining damages.
This saw got abused over an extended period of time, broken & quick fixed, then further abused.
NZsaws
9:30 PM
New Zealand
Hello All.
I'm about to start port work on the Solo 675.
Taken 30 thou of base.
For the top transfers they have a slight curve upwards, anyone have comment if I should follow the factory shape when raising them or is there any advantage to having them straight?
This is the first quad transfer I've ported...
Thanks!
