- 4:34 AM
- Dec 31, 2015
- East Jordan, MI
Nice work. Extensions and bases, too
I agreeThe squish band looks stock. I don't think it's been modified. The couple I have are fairly clean in that ring.
If the ring is still there, it hasn't been modified.
I'll post pics in a sec
I went back into this saw today to check out how it was wearing in. And I saw that I could take more from the exhaust and I doubke checked what I saw with a couple buddies, not sure why I left all that exhaust in there. I left a lot on the table, but I got it now.
View attachment 349284 View attachment 349285 View attachment 349286
Intake looked good and the ring was just barely starting to wear in. I cleaned it up and put it back together after I finished the additional porting on the exhaust.
So I had to take it apart because I got a piece of paper towel down in the intake by accident. It was a good mistake and I guess it was meant to happen.
BTW red armor works really really well.
Thats some nice looking work my friend. I have a beautiful 6400 here with hardly any runtime on it that could use a ported 7910 cylinder![]()
Nothing wrong with the 6400 the way she is unless You process 24+" logs.Thats some nice looking work my friend. I have a beautiful 6400 here with hardly any runtime on it that could use a ported 7910 cylinder![]()
I tried that rakers & 8 pin thing and didn't like it - too uncomfortable when hitting gnarly knots and bucking bone dry logs (chain chatter and slip).
It’s possible that the piston has had .010” removed from it in a previous life alsoThanks again for all the information and pictures of the cylinders. I guess I have to believe that my cylinder hasn't been modified. But I checked squish all the way around the cylinder using what seemed like an entire spool of wire, and the lowest I found was 0.023". Maybe I'll order a new wrist pin bearing and put that in before I try and start it just for peace of mind because that's the only thing I can think of causing this if they're typically too tight for a BGD.
@mettee is who I bought the piston from and I don't believe that to be the case.It’s possible that the piston has had .010” removed from it in a previous life also
IMO, .040-.050 solder is a bit big to get it squished enough to have an accurate measurement.So I circled in red what I'm refering to as the "flaired" cutouts. swooping cutouts for the bottom end to feed into the lower transfers. I was unsure if those were typical for a 7910 cylinder or not. But they were very sharp with some dings so I beveled them a bit. Probably not much concern as the windowed cylinder shouldn't even travel over them. I just didn't want to remove much meat as they seem quite thin.
I also circled in green the base band. I think it was cleaned up by someone at some point because it doesn't have any build up like the rest of the cylinder head had. But it also don't have room to either in regards to combustion area.
I used a couple different solder diameters. I ended up getting the most consistent results with the .040 or .050 wire. I can't remember off the top of my head which it was. Pretty narrow stuff though.
I appreciate everyone's time and responses. I'll check once more before I button the rest of the saw up tonight but in the end, "it is what it is" and "it isn't what it isn't".
Bingo. Btdt. I use .026 diameter solder. If the squish is bigger then that I’ll twist a couple pieces together.IMO, .040-.050 solder is a bit big to get it squished enough to have an accurate measurement.
