Dolmar 6100 high needle adj?
CoreyB
1:42 PM
South east iowa
Ok I have a 6100 I ordered what I thought was the right tool. A double d.
It doesn't work. In fact the head of the needle looks completely round. Am I mistaken on it being a double d? Did they ever use something different? I will try and get some photos up.
RedFir Down
12:42 PM
Idaho
Looks like that screw takes a regular D screw driver (single D) from the picture.
CR888
4:42 AM
It could be a Chinese DD tool that is the wrong size.
This does happen from my experience with the cheap china carb drivers, bit hit and miss but that is what most can only buy. An nice OEM set would be perfect but hard to find. I have had to touch up some carb drivers with a dremel to get acceptable fit.
CoreyB
1:42 PM
South east iowa
I think that is the problem I got a kit off amazon and I am guessing it is not quite right. I will take a dermal to it. Wish I had a d needle out so I could see where it is hitting.
CoreyB
1:42 PM
South east iowa
Ok so I dremeled on it a bit and it now works not a positive engagement and hard to tell when it is adjusting? I think I may need to grind some more but not sure where.
