does anyone know where I can get parts for a John Deere 624 rototiller it has a h60 Tecumseh on it!
pauluza33
Active OPE Member
6:12 AM
idaho
I have a mid 80s John Deere rototiller and I'm having a hard time tracking down a carburetor and adapter for the engine. I don't think it's really a manifold but it may be.
Stihlbro
8:12 AM
Virginia
We have the same tiller, it currently has the carb set up off a 6 hp Techumseh off a Troybuilt.
pauluza33
Active OPE Member
6:12 AM
idaho
So did you use the intake manifold also? Originally they had an adapter that makes the carburetor sit level and it wasn't like the tube style. That is the part I can't find. I found a carb on Amazon for 14.00
Stihlbro
8:12 AM
Virginia
Let me double check. I remember the adapter.
Jody Hutton
Active OPE Member
8:12 AM
VA
I have a few extras , do you have the governer linkage
AVB
7:12 AM
Elora, TN
I found a few Tecumseh 34712 listed on Fleabay.
As the name of the part it varies depending who you talk to. Either way it is an adapter be call a mounting flange or heat dam.
pauluza33
Active OPE Member
6:12 AM
idaho
Thanks guys I made one it wasn't as complicated as I was thinking it was going to be after seeing a picture. And yeah all the linkage is there just no carb, flange or fuel tank. And after running the numbers I found its a 1977 624
Jody Hutton
Active OPE Member
8:12 AM
VA
I may have flange and tank..I will let you know
